-   -   need help coolant leak!!!!please overheating (https://blazerforum.com/forum/engine-transmission-35/need-help-coolant-leak-please-overheating-15657/)
felonyblazer96 12-24-2007 08:49 PM
my 96 blazer i guess was low on antifreeze and after i raced sum1 today i pulle up and it was mildly smoking...i relized there was no anti freeze in it so im almost 2 the store and it strats overheating to where it says check gauges.......i put in antifreeze in the add reservoir and put the rest in the radiator.....still overheated then when i looked on the side of my truck i seen the antifreeze in the snow.......i bought 2 gallons of water and put them in the radiator and as soon as i do that i look under it and its coming out fast but not from the radiator.....it drips down off the oil pan..like where the oil drain plug is..........please tell me its just a belt or something minor!!!!!!any help would be nice.........christmas and this happens
Chevy Lover 12-24-2007 10:00 PM
RE: need help coolant leak!!!!please overheating
Check to see if it's leaking from the bottom of the water pump or the frost plugs in the sides of the block.
felonyblazer96 12-24-2007 11:05 PM
if they are what is it going to mean? it drips down from above and drips off by the oil drain plug....but i think it may be like running to their because it leaks a little bit a little closer to the front..
4x4willywill 12-24-2007 11:25 PM
ok first off ... check ALL hoses , THEN check around front of engine by the water pump, and if you STILL havent found the leak then look around below spark plugs and on dipstick for goldish milky oil if you find it on dipstick you either cracked the headgasket or head Or worst case the Block~!
dont forget the HEATER hoses for heater core can cause the leak too .. alot of ppl forget they hold fluid lol
felonyblazer96 12-24-2007 11:29 PM
mytruck starts up fine......my heater has been giving me alot of problems lately! like i gotta punch the compressor for it to work......i listened for the leak and it sounded like it was bubling out of a hose....does a water pump make that noise? il def check the coolant tomorrow....if no coolant in oil should i be ok? if it was that would it still start
felonyblazer96 12-24-2007 11:46 PM
i miss my blazer :) i wouldnt even leave it i sat in it 4 for hours until i got ahold of my uncle to tow me
felonyblazer96 12-25-2007 10:48 AM
any other advice?
rriddle3 12-25-2007 11:51 AM
ORIGINAL: felonyblazer96
You do realize that the compressor and the heater have absolutely no connection to each other's operation, right? The defroster and compressor, yes, but not the heater and compressor. As for the leak and the bubbling sound, if you can verify thatnone ofthe hoses are leaking, look at the side of the intake manifoldarea that the leak appears to be dripping from, especially the rear portion. You might have a leak from the gasket and it could be running down the engine block.
swartlkk 12-25-2007 12:53 PM
any other advice?
Have you even bothered to take the advice given? Or is this thread destined to sit just like the other threads...?
What have you done to try to rectify the situation?
felonyblazer96 12-25-2007 01:18 PM
um nothing because im 50 miles away at a party........cnt do nothing till tomorrow and i wanna see all possibilities.....if you aint got advice dont talk to me
