need help don't know what else to try
Old Mar 12, 2008 | 07:21 PM
cvcmama22's Avatar
cvcmama22 is an unknown quantity at this point
Default need help don't know what else to try
i have a 92 jimmy 4.3 vortec went to work and started running rough when i got to work came home still running rough replaced spark plugs ,wires , cap, buttons, o2 sensor, both trottle relays , water sensor ,fpr sensor ,fuel filter, map sensor,tps fuel pump getting 62 psi at the engine sparks plugs getting blue spark, took off the cat and put a new muffler on starts sounds like its missing rough idle still checked to egr valve thats fine put a code reader on and says things r fine passenger side manifold is warm the driver side manifold is hot replaced those things one at a time when one thing didn't work tried something else vacuum is about 5 need help please
Old Mar 13, 2008 | 09:40 PM
94blazer4.3ho's Avatar
94blazer4.3ho is an unknown quantity at this point
Default RE: need help don't know what else to try
5 pounds of vaccum does not sound right for these engines. What is your compression in all cylinders? You could have a bad air leak in your intake manifold, maybe replace your intake manifold gasket, uper, and lower. If your compression is low id check for blown head gasket. Five psi. of vaccum is way low. Any check engine codes?
Old Mar 14, 2008 | 08:35 AM
cvcmama22's Avatar
took the plemon off again and this time found gas in the inside i was told thats not good so i got the fuel injector going to see how that works today if its still missing we'll check the manifold and the vacuum again code that come up 12 and thats normal but u can hear its not normal
Old Mar 25, 2008 | 01:20 PM
jester429's Avatar
jester429 is an unknown quantity at this point
Did you ever find out what the problem was?
Old Mar 25, 2008 | 08:01 PM
cvcmama22's Avatar
replaced the spiderwith anew one still had problems got tried of it and took it to a garage they said the spider was bad took it back got a new one blown out the return line with air still not right something still not there
Old Apr 7, 2008 | 05:55 AM
cvcmama22's Avatar
find the problem broken valve spring
Old Apr 7, 2008 | 06:41 AM
Yikes! That would do it though! Thanks for the followup!!
ckroll98
Jun 27, 2013 04:41 PM
IanD
Oct 14, 2012 07:17 PM
88s10Blazer
Lifting Tech
34
Oct 17, 2010 02:50 PM
Redneckgirl
16
Dec 6, 2008 09:40 AM
havrelm1
Jul 24, 2008 09:26 PM
