-   -   Need Help With Engine Knock (https://blazerforum.com/forum/engine-transmission-35/need-help-engine-knock-91744/)
Blazer9614 01-26-2016 09:11 PM
S I have been dealing with this for a little while but it seems to be getting worse. I have a 1996 s10 blazer super base model and lately I have noticed that I have some sort of a knock. now this know is not constant, it is only at idle. you can hear it in park but its the worst in drive while being stopped. it tends to go away when I up the idle by two stepping or when I start driving. if I am stopped and do something to increase the load, such as turn the steering wheel the knock gets louder. I just was wondering if anyone out there is having the same issues I need help because I really don't want to start tearing it apart to find out what it is if there is someone out there that is having the same issue and has found a solution. I keep regular maintenance on the vehicle but keep in mind I have only had it for about 2 months. it has 107000 miles and just a side not when I got it the tranny fluid was pretty low but I don't think that is causing my issue cause it is full now. someone help me please....:(
Blazer9614 01-26-2016 09:31 PM
just a quick update. I found a tsb that says it could be caused by excessive oil consumption which kind of makes sense because I am due for an oil change. I will check my oil tomorrow when it is daylight and do an update. the tsb said this is caused by oil seals on the exhaust valves so I might look in to that soon. I would still like to hear your guys's opinions though. I will be doing an oil change probably next week and I will let you guys know if I find anything worth sharing or it it helps the problem at all.
LesMyer 01-27-2016 01:02 PM
Does it sound like this (video in post#1)? https://blazerforum.com/forum/2nd-ge...g-valve-87514/
Blazer9614 01-27-2016 01:11 PM
It's not as prominent and it goes away if I increase rpm but it has about the same rythem just not as loud
LesMyer 01-28-2016 07:18 AM
Mine also went away with increased RPM. Does noise start when the engine is warmed up, and is not present when the engine is cold? Post a video of yours.
Blazer9614 01-28-2016 07:53 AM
Yes it starts when it's warm. I'll try to get a video later today if I have time.
LesMyer 01-28-2016 08:12 AM
I'll wait for the video, but sounds like a lifter is collapsing at idle when engine is warm due to insufficient oil to it. Mine had excessive bearing clearances, presumably due to previous intake gaskets leaking coolant into the oil, and when warm and at slow idle it simply couldn't keep a lifter fed. I bought someone else's problem.
Is your SES light on? Does it work with key on/engine stopped? Mine was disconnected and the wire taped. Didn't notice that my SES light didn't work when buying the vehicle. Since then have figured out that excessive bearing clearance can whack out the misfire detection system and cause false misfire codes to be set.
Again, let me wait for the video. Also please describe oil pressure cold and hot, idle (in drive) when ticking and at 2500 RPM. I think you will find a big difference in oil pressure between when it is ticking at slow idle, and the RPM where it stops ticking.
Blazer9614 01-28-2016 08:18 AM
My ses is not on. I am a little low on oil though, I will be doing an oil change probably monday. My oil pressure is and 60 when cold and at idle and when It starts ticking is about 40-50 and when it's warmed up completely it's about 40 and I don't have a tach but at 65mph it's between 45 and 55
Blazer9614 01-28-2016 01:37 PM
http://https://youtu.be/StLANL_pZSw
Sorry if the sound is bad but this is my knock
Blazer9614 01-28-2016 06:27 PM
So I'm going to school to be a diesel mechanic and we share a building with the auto tech and today the auto tech instructor took a look at my blazer and seems to think it's a thrust bearing because the harmonic balencer is moving a little bit. Can anyone agree with this judging by the sound in my video? If it is a thrust bearing I'm just gonna run it till she blows
