-   -   need help fast (https://blazerforum.com/forum/engine-transmission-35/need-help-fast-18522/)
strong blazer 03-19-2008 10:55 AM
need help fast
i hav repaired oil pump on my 91 4.3 4dr blaze ive got oil leaks there are new gaskets on oil pan and valve covers and rear main but today i noticed and small oil leak coming from behind the harmonic balencer is this an hard repair and can any one walk me through it ? please help i want to drive my baby again like i used to oh and it has 138,000 miles on it
swartlkk 03-19-2008 11:04 AM
RE: need help fast
To replace the front lip seal, you need to first remove the accessory drive belt(s). Then remove the crank pulley (3 bolts IIRC - if equiped) and the harmonic balancer retaining bolt/washer.
Next, install a puller to remove the harmonic balancer. A low profile puller may be necessary. I made one out of plate steel with 3 holes to match those in the balancer (used for the pulley) and a larger hole in the center with a nut welded to it. Thread a bolt through the welded on nut and walk the balancer off.
You will then need to pry the old lip seal out of the timing cover, and press in a new seal. Pressing in the new seal can be a challenge with the timing cover still on the front of the motor...
strong blazer 03-20-2008 09:40 AM
RE: need help fast
thanks for the help i might just need to let my dad do this one cause i dont want to f it up or anything because i never to do this to any of my other cars i own
