needing some help pleaseeeeeeeeee
Ok heres my prob my horn wont work my electric hatch wont pop open my dome lights when i open the truck wont work all of a sudden it was fine before...I check the fuses they were all fine there 2 bigger fuses on there one says power windows and the other is Power/ACC and i cant see if that ones fine or not when i plug it in and take it out i here a click inder the driverside dashhh..Is there somtthing im missin
RE: needing some help pleaseeeeeeeeee
my buddy just did my heater core is there a ground wire for that somwhere if there are where is it
DUDE! Are you 11 years old? This has nothing to do with Trans or Engines! You just keep popping around here spamming the place up with repeated questions about the same problem. Alota People here have real lives outside of BF. So take a chill pill, calm down, keep the posts together (makes it easyer to figure out what has already been done/tried), and give people a chance to respond. Your not helping yourself by acting a fool. Your not the only oneexpecting a miracle!
P.S. It HELPS ALOT if you put the problem description in the subject as well! |
Hey dont post then on here pretty simple..I didnt even mean to post in here..Ur a idoit
I suppose I egged you on with my first comment, but the rest was meant to be helpfull! I appologies that it came out rudely. Good luck
| All times are GMT -5. The time now is 05:19 PM. |
