New AC Delco O2 sensor, same codes
Old Dec 29, 2007 | 07:18 PM
jdbell2004's Avatar
jdbell2004 is an unknown quantity at this point
Default RE: New AC Delco O2 sensor, same codes
thanks. what about this sensor should i focus on considering my symptoms?
Old Dec 29, 2007 | 07:29 PM
To me it sounds more like a wiring issue. Intermittent things like this typically are not caused by a faulty sensor...
Old Dec 29, 2007 | 07:36 PM
jdbell2004's Avatar
where on the wiring should i look for a short?
Old Dec 29, 2007 | 07:38 PM
Can't answer that question... Look for places where the wiring harness may be pinched. Look for abrasions to the harness casing. Other signs of abuse... Wiring faults are one of those things you just have to get your hands dirty.
Old Dec 29, 2007 | 09:48 PM
jdbell2004's Avatar
could this have caused my temp sensor codes?
Old Dec 29, 2007 | 09:51 PM
That is a distinct possibility.
Old Dec 29, 2007 | 09:59 PM
jdbell2004's Avatar
could that cause the spark plug wire directly under that to arc to that open connection?
Old Dec 30, 2007 | 08:39 AM
If the insulation on the plug wire is intact, it shouldn't.
Old Dec 30, 2007 | 05:44 PM
jdbell2004's Avatar
just curious cuz it hasnt stalled like it had been in the last 400 miles since I changed that coolant temp sensor... although it still seems to be missing. It idles rough unless I've been doing some highway driving and when it does idle rough, if I keep it in park or neutral and rev it to about 2k you can hear and feel it missing....why? bad plug wires?The SES is still on as well. Does pending DTC codes mean stored or current?
Old Dec 30, 2007 | 06:35 PM
If you didn't clear the codes after replacing the coolant temp sensor, it could still have a stored code for that. After a few drive cycles that code should clear though.
