-   -   new distirbutor, blue smoke engine turned backwards (https://blazerforum.com/forum/engine-transmission-35/new-distirbutor-blue-smoke-engine-turned-backwards-29077/)
bodhifirestarr 03-26-2009 03:17 PM
This is the jest of it all. I put in a new distributor, turned the engine to TDC of the #1 cylinder, compression side, moved the oil pump the correct position, installed the new distributor, started the blazer and it seemed to run fine. That was yesterday. When I went to start it today, it didn't want to start, started blowing some blue smoke, and when I stopped trying to turn it over, it ran backwards a couple of cylinders. What is my next step. The service engine light came back on as well.
swartlkk 03-26-2009 03:29 PM
Ran backwards...
How did it sound when it was turning over? What prompted you to replace the distributor?
bodhifirestarr 03-26-2009 03:51 PM
I had to replace the distributor when I broke it after replacing the knock sensor. I went to put it back together and then broke the cap and housing screw holes. So I put it in. Started it yesterday and it seemed fine. Went to start this morning and it acted like it didn't want to start. Almost like it was out of time. The noise was normal engine noise when it is turning over, it just didn't fire off. Then went backwards slightly.
bodhifirestarr 03-26-2009 07:41 PM
so can anyone help me with this issue or should I just call it quits and take it to the chevy shop
WolfPack 03-26-2009 07:59 PM
I didnt know they could go backwards...wow..
rriddle3 03-26-2009 08:05 PM
What Kyle and Jason are trying to tell you is that nobody understands what you are trying to say when you state that the engine 'went backwards'. Can you clarify that statement?
BlazinMike89 03-26-2009 08:15 PM
did u install the spark plugs in the right order on the distrubutor
** i see it ran fine before***
Johns1987Blazer 03-26-2009 08:23 PM
Timing sounds like its too retarted, turn the distributor clockwise in 1/4 in increments until it fires. To properly set the timing, you will need a timing light. hope this helps.
bodhifirestarr 03-26-2009 08:33 PM
Well to clarify, I hope, the running backwards, it turns over like it is supposed to, then when you let off the key, it stops and then chugs the other direction I would say maybe one or two seconds. not really "running", but moving opposite the way it is supposed to go. The plug wires were installed according to the numbers on the wires, and cap. Following them, they lead to the appropriate cylinder, so I went ahead and put them back on the same way, 1 on 1, 2 on 2, etc. Would having the knock sensor installed and not torqued properlly cause this same issue?
swartlkk 03-26-2009 08:56 PM
You cannot time the 96+ SCFI motors with a timing light. You have to align things properly.
I recommend you go through the EDI Engine Timing thread (in the Tech Article (DIY) section) and make sure that the distributor is installed properly per the alignment marks on the balancer and what is on the inside of the distributor.
