-   -   New here with a few questions. (https://blazerforum.com/forum/engine-transmission-35/new-here-few-questions-53469/)
Hosser Jan 1, 2011 11:05 AM
I apologize first off if this is in th wrong section.
Here goes, '95 S-10, 2WD , 256K miles.
Newly rebuilt transmission, numerous new motor components due to following issues.
Typical stalling out problem, replaced fuel pump (pressure and bleed down is fine), spider, cap and rotor, plugs and plug wires, etc... nothing comes up on diagnostics that I have.... thinking main computer and the small wiring harness inside the spider which for some reason I didnt replace (stupid I know). Mechanic I use has run through this thing so many times over the years its to the point either new motor or junk it.
Can I by chance get some resources for complete wiring harnesses you recommend, general cost on rebuilding existing motor and rather or not a NIB computer or a refurbished one would be fine.
Thanks
Hosser Jan 1, 2011 01:50 PM
I found this, but it says it wont work for my vehicle....I cant find one that does. Its a W code VIN.
swartlkk Jan 1, 2011 01:58 PM
Found what?
A quick search for "CPI+injector+connector" turns up this thread:
95 Fuel injector connector
BWD part number 28413 is correct for the CPI injector. It is the same connector as is used on the TBI injectors.
Hosser Jan 1, 2011 02:01 PM
Sorry forgot to post the link
http://www.jcwhitney.com/fuel-inject...id=c2062d242j1
Thanks for the links!
Looks to be the exact same picture, says in the list it is compatible per O'Rielys.... for an $8 dollar part its worth checking out I guess.
