No codes, running like crap
Runs poorly or not at all. No codes showing. One injector is weeping. Did find a burnt connection for the fan.
Any suggestions. |
Originally Posted by Fred Tapping
(Post 707312)
Any suggestions. |
Bogs downs. Rough idling. Between 8500 and 9500 rpm...jumping up and down. Remember no codes during any of this.
Changed the fuel filter. Cleaned the injectors Used throttle body cleaner. |
So, you know one of your injectors is leaking. I'm sure that's not helping your truck run, any. You'll need to fix any known problems first.
Also, check your fuel pressure |
(Post 707339)
