no oil pressure brand new engine .
Hello guys I need a little help here I can't figure it out , I have all brand new race parts in the whole bottom of the engine . The oil pump is a melling high volume pump and I turned it manually to prime the system and it primed quick . Now its a little tough to turn and will even spin my ratchet back wards if I let go of it , but it is not even pumping oil up to the remote filter . I don't what could be wrong the only thing I can think of is the remote oil filter is wrong or something . I had the distributor in (with the coil not hooked up ) and turned it over for a while thinking maybe I wasn't spinning it fast enough , but still nothing . Any ideas ?
After doing some research I have come to the conclusion that I either installed the bearings wrong or the bearing tolerance is incorrect . I am going to take off the remote oil filter and make sure its not that but I have a bad feeling I'll be pulling the engine back out tomorrow .
Yea I thought I did , I bought the book and had the engine in my shop for over a month , And in and out of the blazer several times . I don't think its the bearings I used plasti gauge on the crank and rod bearings . I'm hoping that it has something to do with the remote oil filter assembly , before I installed the remote oil filter bracket on the block ( one turn of the distributor ) oil would shoot out . Bam it just came to me in the middle of this post there is a piece of pipe threaded on the inside and on the out , it is used to connect the oil relocater to the block and its threaded in to far not letting the oil get to the line . That has to be it . UPDATE I messed up the oil lines they were marked in/out - in/out so I hooked the in to the in and the out to the out and that was wrong , but all is good the engine runs great , I'm very pleased .
bigdaddykane93
Sep 22, 2009 08:42 AM
zombiewoof
Feb 1, 2009 12:06 PM
