no spark
Old Nov 6, 2007 | 08:14 PM
danyrm's Avatar
danyrm is an unknown quantity at this point
Default no spark
We have a 99 jimmy with the 4.3L. With a no spark issue. It died on the way home from the doctors office. I recently did new plugs. So i decided sinceI had the stuff to illiminate the plug wires cap and rotor. The jimmy fired right up ran great. I wondering if it isnt the Ignition control module or coil heating up and then going out.. Is there a way to test them. Ive heard autozone does it. Is this true. Does anyone have any ideas. Am I on the right track?
Old Nov 7, 2007 | 05:49 AM
jackstraw278's Avatar
jackstraw278 is an unknown quantity at this point
Default RE: no spark
I am not really much of a mechanic, but it sounds like you are on the right track. I'd try pulling one of your plug wires, put a screwdriver in it. have someone else crank it while you hold the screwdriver (carefully) about 1/2 an inch from the engine somewhere. If it is sparking properly, you will see it. It would be a good start at least. Like I said, I'm not much of a mechanic, I wish I could be more help.
Old Nov 7, 2007 | 05:56 AM
danyrm's Avatar
I use a extra plug for that. Thats how I established a no spark issue.
Old Nov 10, 2007 | 10:40 AM
AJBert's Avatar
I would be suspect of the coil first if it starts fine when the engine is cool.
Old Dec 2, 2007 | 09:22 PM
danyrm's Avatar
After alot of chasing and replacing burnt out sensors I figured it out. The wiring harness was shorting out causeing sensors to burn up.
Old Dec 3, 2007 | 01:48 AM
Chevy Lover's Avatar
Where was the harness shorting out?
It might help someone out in the future to know.
JavierEscalonJr
Oct 14, 2020 11:38 PM
blazzer
Jun 4, 2013 04:40 PM
abe_f
Apr 1, 2013 11:19 PM
Yankee Team1020
23
Aug 3, 2011 08:05 AM
thorbergdt
Engine & Internal
Jan 5, 2005 10:02 PM
