Originally Posted by bigblock540
(Post 742017)
Ok well I have issue still. Ran new circuit and it shifts 1 time then blows 10 am fuse.I moved my circuit to a different spot,same thing.I have these codes po758,po740,po753,po785. I replaced both a nd b solenoids with new GM before I did the new circuit.
Do I have a shorted internal harness ? |
Connector is dry,I'm going to ohm out all the solenoids and the harness. Does anyone know ohm readings on all the solenoids? I know a and b should be around 20ohms but not sure bout others,maybe like 10 or so on the pressure solenoid lol idk. Tks for reply though preciatit!
| All times are GMT -5. The time now is 09:27 AM. |
