-   -   Not sure where to start (https://blazerforum.com/forum/engine-transmission-35/not-sure-where-start-89906/)
tlamana 05-24-2015 06:42 PM
1994 S10 Blazer 4x4.
Found that transmission fluid was way low when I got the truck. I topped off the fluid and it stunk for a bit but went away. Probably deglazed from running low. Now it revs fairly high but does seem to shift through all gears. It is a bit sluggish and the CEL does pop on and off occasionally. (No I have not been able to run codes).
What I am looking for is possible causes as money is tight. I don't want to R&R for no reason.
Thanks in advance.
