Nv236 with 3 button switch
Old Oct 5, 2012 | 11:27 AM
Stangski09's Avatar
Stangski09 is on a distinguished road
Default Nv236 with 3 button switch
Ive noticed my 4wd humming while im driving, so i tried troubleshooting my 4wd and after I had raised the truck ive come to a conclusion.
The truck will go into 4hi/lo fine. But it wont go back into 2hi from 4hi unless i push the button a few times and put it in neutral, or it will come back into 2hi if i go from 4lo to 2hi.
I also notuced that i do not have a vac switch on the case. So i believe it is an nv236, however i have a 3 button switch in my dash
So my question is would a 3 button switch in place of a 4 button cause this problem?
Ill be acquiring a 4 button switch later today to try, and ill update.
Thanks for the help!
Old Oct 7, 2012 | 08:51 AM
Stangski09's Avatar
Buddy with the 4 button switch is being difficult. So im still waiting to receive it.
While i wait to acquire it can someone chime in on this, i think the proper switch should lrobably fix my problem..?
Old Oct 7, 2012 | 09:45 AM
50lb_cat's Avatar
https://blazerforum.com/forum/tech-articles-diy-29/4wd-front-axle-clicking-when-2hi-goes-away-when-4hi-4lo-41226/
The link explains how to diagnose the front axle issues you are having. Look at your rpo code in the glove box. IIRC, NP1 is the 3 button switch and NP8 is the 4 buttn switch, with auto 4x4.
762mm
17
Nov 21, 2024 11:36 AM
Flyfishen
Jun 18, 2019 11:22 AM
gil
Jan 28, 2010 09:26 PM
S10 TrailBlazer
Dec 13, 2009 07:42 PM
