OBD II diagnostic interface
Which cheap diagnostic interface for Chevy Blazer 1998?
Not sure what you're asking? Are you asking what will read codes? Any OBD2 compliant scan tool will read codes from that truck, including the Bluetooth and wifi modules you can pair with your phone. I have a Bluetooth one that I use and it works great. I would suggest doing a bit of research to make sure you get one that meets your needs.
Originally Posted by Bibol
(Post 691989)
Good phone apps:
Also have Scan XL Pro with GM Enhanced PIDS for Windows - $150 + USB OBD2 adapter - light speed in comparison to Bluetooth but Car Gauge Pro does more functionally. Supposed to do ABS, but I have not verified. Seldom use it anymore. Was my first software after Torque Pro, bought to do cam sensor retard. Needs a laptop. Also have HP Tuners VCM scanner for Windows with GM package - $350 has it's own OBD2 adapter - does crank sensor relearn, injector balance testing, transmission control, fan control, solenoid control, other bidirectional control. Only use it when I need more than Car Gauge Pro. Needs a laptop. |
I have an ELM 327 Bluetooth OBD2 mini interface. I use Torque, Piston, Obd Army, EOBD Facile, DashCommand. Unfortunately, no application connects to my car. I checked with other European cars and the sale is OK. That's why I am looking for an affordable interface with 100% certainty that it will connect to my car. I want to read and remove the ECU error. I will be happy if it can be combined with the gearbox. What do you recommend?
(Post 692114)
http://www.onboarddiagnostics.com/images/j1962pwm.gif (note this image is incorrect for Blazer see post #8) Dash Command will definitely read Powertrain (engine and transmission) codes on a 1998 Blazer, as will Torque Pro. If you are using pirated copies of these programs, that could also be a possible issue. Good luck and best wishes. Let us know the result. |
In my car are available pins 2,4,5, and 9,13,16. Pin number 10 is empty. Are you sure that OBD II connector from this photo concerns my car? Chevy Blazer LT 4.3 V6 4WD 1998y.
Any suggestions?
Sorry, you have J1850-VPW. The one I gave you previously by mistake was the original Ford protocol (J1850-PWM).
Here are the mandatory wire pinouts for the various OBD2 protocols that were used (can be additional pins present but these wires are mandatory for the protocol to work). Still need to check for 12V and ground on the correct pins. Do you have a test light or a multimeter? OnBoardDiagnostics.com - OBD-II Network Standards |
I checked. There is power. Today I ordered "BAFX Products® Bluetooth OBD2 reader". He will reach me in about 6-8 weeks. I hope he will connect with my car.
(Post 692275)
| All times are GMT -5. The time now is 06:56 PM. |
