oil change
i am now at the point unfortunatly in 1ft of snow having to change my oil..i tried yesterday but the drain plug will not come off, its liek they put gorilla glue on it can some1 please help and tell me the best ways to remove the plug with stripping???? id appreciate it [/align] |
RE: oil change
anyone?
RE: oil change
Calm down there killer... No need to bump a post a mere hour after the first one.
Have you tried heating it? Not a ton of heat, but a bit... Also, are you using the appropriately sized wrench/socket? I know that sometimes with drain plugs, a standard will fit better than a metric so try out a few different sizes to get the one that fits the best. |
RE: oil change
Ya heat it... if its stripped try some fluted bolt extractors, they work like magic!
RE: oil change
I know of two different sized plugs that have been used on Blazers, a 12mm or a 15mm. I suggest a good box-end wrench for the job.
RE: oil change
and if its on that tight use another tool to add leverage.
RE: oil change
how do i "heat the drain plug"?? thanks guys [/align] |
RE: oil change
is it a tool you buy to heat it?? im lost on that [/align] |
RE: oil change
you/girlfriend/mom got a hair dryer?
RE: oil change
thats all it takes??? i dont have a garage so i gotta do it out side [/align] |
