Originally Posted by cleburne red
(Post 618739)
I'm one of those who used hose clamps when I made my new lines. I know it's not the best solution, and I should have gone with ones like the Captain said. However, I put two clamps at every end of the hoses, and it's been over a year, and not a single drip!
Who was it that likes to take the lines off altogether? Chris015? I can't remember. He claims it works well, but I like the idea of the oil cooler, and it's a lot easier to access the filter behind the skid plate, rather than up above the driveshaft. K, im gonna be the delete guy... 1st gens come with the nipple you need...gm part # 14081300. You can buy it new for 12 or so bucks at the dealership,or if your nice i can get it for ya at the yard,it comes removable on 1st gens. remove the lines,the adapter,chunk off the old gasket on the inside of the block,install nipple with torx wrench. screw on filter (pf47 filter,if you cant find it,cross ref that part #) its shorter and will work for 4wd) Ive done it 3 times. im hard on these trucks,never a problem. if you tow,KEEP the lines. if its just a whatever driver....do it..... |
Of course you're remembered, how could we forget? ;)
LOL <3 i try.
but OP,if you must delete...then follow what i said. Ive done it 2-3 times,never a issue. but if you do indeed tow etc,keep the lines. |
Deleted mine, will never look back.
Originally Posted by chris015
(Post 618759)
Woohoo...im remembered. LOL
Ive done it 3 times. im hard on these trucks,never a problem. if you tow,KEEP the lines. if its just a whatever driver....do it..... Yeah, for daily driving, the cooler isn't really necessary. Most vehicles probably don't even come with one. I like to imagine hard-core off roading, and zombie apocalypse rock climbing, so I wanted to keep mine! LOL |
chris015, do you know for sure if the filter will clear on a second gen? if I do decide to do a total delete I want to be sure it will work before I go ripping parts again. the filter that is used is the same that gm used on all their v6 cars I pretty sure. 3.1, 3.4, 3.8. I think im going to end up keeping the lines and just do the good fix to them because I do tow my four wheeler on occasion and my boat / camping gear once or twice a year. how much cooling dose the cooler actually do? I know it adds extra capacity and surface area for heat to dissipate . but the rad cooler really wont cool to much until the engine oil is above coolant temp right? im wondering if I would be ok with doing the delete and running a quality oil? I don't think this engine has much life left anyway ... will the stock cooler lines fit with a v8 swap? Vortec 350 not LS unfortunately .
Besides being 2 cylinders short of a 350 the 4.3 is the same as a v8 dimensionally. I almost put the waterpump off an 88 305 on mine the other day. I also have a few 3.8 sensors on mine as well. It's a frenkenstein.
I've deleted the lines on my 2nd gen Sonoma I'm building. I used the filter off of a 2.2 cavalier/sunfire and there's enough room.
Originally Posted by 2000jimmbo4x4
(Post 618861)
...how much cooling dose the cooler actually do? ....but the rad cooler really wont cool to much until the engine oil is above coolant temp right?...
This link covers the subject very well: http://www.jagsthatrun.com/V6-instru...er-removal.pdf |
I removed my ext filter and cooler and have had no issues.
| All times are GMT -5. The time now is 11:49 AM. |
