-   -   oil dipstick tube (https://blazerforum.com/forum/engine-transmission-35/oil-dipstick-tube-72456/)
ewarma Jul 21, 2012 11:24 PM
oil dipstick tube
i just replaced my head gaskets on a 2000 4.3L vortec. now my dipstick wont fully seat in the tube. I had to move the tube when i was putting the exhaust manifolds back on so i think it has come out of the block. if so how do i get it back in? any help is appreciated.
Whisper6691 Oct 20, 2015 10:12 AM
I have a 2000 Chevy Blazer Vortec V-6 and for those that need to know how to install the press in oil tube without damaging it. (there is no O-ring on these) this is a metal tube and trying to get it in the block had been challenging. Most people try to force or grind down the collar, and even try to shave a portion off. No need to do this. A simple solution is as follows. Simply put the dipstick tube in your freezer for a few hours (recommend a minimum of 5 to 6) this allows the metal to shrink. Then insert the tube into the block. You will notice it is a bit easier to push it partially into the hole. After it is inserted and positioned in the direction you need it to be, simply take a pair of vise grips and carefully lock around the tube just above the lip (without damaging the tube. Take a hammer and slowly tap till the tube is fully seated. There it is fully inserted to the proper depth and no damage to the tube.
I posted this in a new thread
