-   -   oil drain plug? (https://blazerforum.com/forum/engine-transmission-35/oil-drain-plug-20741/)
sasquatchfound 05-15-2008 01:36 PM
oil drain plug?
I know this may sound stupid, but doesn't the drain plug for the oil turn the same as any nut would (righty-tighty/lefty-loosy)?
Thanks, Shane
blazin97 05-15-2008 01:37 PM
RE: oil drain plug?
yes it does. You are stupid...jk...lmao
sasquatchfound 05-15-2008 01:40 PM
RE: oil drain plug?
lmao blazin. Ok with that said why wont the dang thing screw back in?
Thanks, Shane
cliro 05-15-2008 02:02 PM
RE: oil drain plug?
lefty loosey, righty tighty..lol
curse 05-15-2008 02:15 PM
RE: oil drain plug?
i never followed that, always went with clockwise/counter clockwise.less room for error because someone forgets.
RCars2 05-15-2008 02:37 PM
RE: oil drain plug?
ORIGINAL: sasquatchfound
Thanks, Shane
Make sure there is no debris in the way of the drain hole (basically just run your finger along the threads or use a rag). Also check the threads of the plug to make sure they aren't all messed up and/or cross-treaded. If neither or those makes any difference you can pick up a new plug from you local auto parts store for under $10. If that screws in, then you plug is buggered up, if that dont work then your drain hole is messed up and needs to be re-tapped.
sasquatchfound 05-15-2008 02:56 PM
RE: oil drain plug?
well when i got the plug out and i was turning toward the back of my blazer, the plug had a thin strand of metal rapped around it. I;m guessing i need to rethread it. would it be cheaper for a new thread or anew pan?
Thanks, Shane
sasquatchfound 05-15-2008 03:55 PM
RE: oil drain plug?
Ok, called the parts store they told me about a larger self tapping plug. Has anyone used one of these and are they safe to use on my oil pan?
Thanks, Shane
