oil fiter help please
Old Apr 16, 2013 | 06:51 PM
chevycam33's Avatar
chevycam33 is on a distinguished road
Question oil fiter help please
hello i changed the engine in a 99 2 wheel drive blazer to a 4x4 and the 4x4 has an oil filer under the front bmper but the engine also has the one on the side. the one on the engine hits do they make a cap or some thing for that.
Old Apr 16, 2013 | 10:22 PM
chris015's Avatar
nope. Wheres the oil lines and adapter off the old engine? If you dont have it you can find em at the yards fairly reasonable.
Old Apr 17, 2013 | 07:06 AM
cleburne red's Avatar
Like what Chris said. Can't you put the lines and adapter from the 4x4 engine on? Or do you not have them.
I thought I read somewhere on here that all blazers had a remote oil filter, regardless whether it's two or four wheel drive? Guess not.
Old Apr 17, 2013 | 09:11 AM
grizzstang's Avatar
grizzstang is on a distinguished road
I thought that all the Blazers came with the remote oil filter too but on the two wheel drive Blazers a lot of guys were removing the remote filter system in favor of putting the filter directly on the engine because they had room.
Old Apr 17, 2013 | 02:47 PM
There was even a thread a while back where some 4wd guys were ditching the remote filter, and putting the filter on the block. They claimed there was room, but I wouldn't want to have to deal with it.
Old Apr 17, 2013 | 03:01 PM
chris015's Avatar
you use a shorter filter. And you move the nipple the filter screws onto on the old adapter and it threads directly into the block. Thats if u want it on the block.
Cleburne,as far as i know only 4wd had remotes. others was on the block.
Old Apr 17, 2013 | 03:08 PM
4X4GS10B's Avatar
4X4GS10B is on a distinguished road
+1 chris015
Old Apr 17, 2013 | 03:10 PM
chris015's Avatar
il spend my precious time looking for the part # on the shorter oil filter.
(since ive got absolutely nothing to do tonight lol)
FOUND IT! PF47 filter is what you use. or it cross referenced to a fram 3387A
Old Apr 17, 2013 | 05:58 PM
I guess if it's shorter, it would probably work. I was trying to imagine getting the regular sized filter up there!
It would make more sense that the 2wd was on the block. I just thought I had heard they were all remote. Seemed pretty weird to me, but I've never worked on a 2wd before.
Old Apr 20, 2013 | 10:56 PM
chevycam33's Avatar
thanks got the part at junk yard for 20 bucks.thanks for the help.
