Oil leak
Oil residue in my pcv valve, why? My neighbor said it could be piston rings gone bad and allowing pressure to blow past through the value cover into the pcv. Anyone knows about this problem?
A small amount of build up I would think is normal, The PVC valve removes oil vapors ect from crankcase and vapors are routed to the intake so they can be burned in the engine instead of releasing them into the air
Hey thanks for the info,I also noticed that I may be having a leak from the oil cooler seals, I picked up a kit this morning
If oil was passing through the rings wouldn't my truck be giving off some type of smoking?
BTW, how did you guys post your profile picture, I'm new to this. . |
