Oil Pan
I busted my oil pan acouple of weeks ago four wheeling and i was wondering what would be the easiest way in changing it? Thanks
RE: Oil Pan
What are we talkin' about here? Year would help greatly. I can assume a 4wd which means you pretty much have to either drop the front axle or jack the motor to get the pan off.
If it is a '96+ truck with the cast oil pan, then you will really have to pull the motor to replace it. The oil pan is a structural member of the engine/transmission. If the transmission is bolted up when you install the replacement pan, you will most likely have leaks due to misalignment. |
RE: Oil Pan
Yea its a 93
| All times are GMT -5. The time now is 09:45 AM. |
