Oil pressure problems
97 blazer LS
4door 4Wheel drive
I have onwed my 97 blazer for about year and a half now, since i've owned it my oil pressure has been 40@ Idle and 60@ driving speed.
About 5 months ago my gauge started droping to 0 when i hit a bumb or turned hard. I ignored it thinking it was a short in my dash. i check my oil a few weeks later seen i was low so i changed my oil. I'm pretty sure i put Mobile one 10W40 in. went back to normal for a bit then my gauge started to move around, never below 35 PSI and all ways just below 60 while driving.
I just change my oil Mobile One 5w30 and as I all ways do i did a seafoam treatment, and today i chngend my Oil pressure switch.
started the truck up and my oil jump to 60+ PSI. i got it up to temp and to help 40+ @ idle and 60+ @driving normal heavy footed it got to all most 80.
I'm not sure if i messed something up when i installed the new switch or not. any clues?
4door 4Wheel drive
I was hoping no one would say my oil pump, i don't feel like replacing it. but i was just reading some tother threads about the same problem so i'm thinking faulty oil switch, bypass vale, or clogged pcv valve.
Very well could be sorry to be the first to say oil pump lol
How many miles are on the motor ? and has it ever been rebuilt?
Last edited by swartlkk; Sep 26, 2012 at 07:47 PM. Reason: *COMBINING CONSECUTIVE POSTS* Please use the edit function to add additional information to your post if another member has yet to reply. Rules are Rules.
At one time I had extremely high oil pressure in my 89 Jimmy 4.3 TBI to the point it would blow oil out of the dipstick tube if it was not seated. It would also pop out the PCV valve. I could not figure out what was going on for the longest time. I decided to rebuild my TBI unit and it turned out the the port on the TBI unit for the PCV system was totally plugged. So I had no crankcase ventilation. Once I cleaned out all the ports and re-assembled the TBI unit the Oil Pressure was normal.
LWegner
May 8, 2011 08:25 AM
Spectreblazer
Mar 15, 2010 11:16 PM
davidsv8mustang
Feb 18, 2010 02:29 PM
Ak95Blazer
Jan 7, 2009 06:56 AM
