-   -   oil pump low pressure (https://blazerforum.com/forum/engine-transmission-35/oil-pump-low-pressure-74496/)
hellblazer 10-15-2012 07:41 AM
i wanted to know f anybody knows why the am i getting low pressure reading ob my oil gauge.i just changed the oil sat.and this morning i noticed it being at 35psi.what is normal reading supposed to b.
Bdub 10-15-2012 07:52 AM
I think mine is 40 at idle fully warmed up
05BlackJimmy 10-15-2012 08:01 AM
I know the gauge is supposed to be almost at the middle while idling and when accelerating it goes up past the middle. Did you check the oil level?
newguy 10-15-2012 08:37 AM
oil does get thinner when warm, which would show less pressure. What weight did you put in?
rriddle3 10-15-2012 09:10 AM
Rule of thumb: 10 psi needed for each 1k RPM. GM specs 8psi minimum for our engines.
hellblazer 10-18-2012 05:39 PM
i use 5w30 high mileage castrol gtx.i guess its normal.thanks eveyone.
1sttimejimmyowner 10-22-2012 05:19 PM
40 psi @ idle after fully warmed is good.
My 4.3 in my truck starts up at 60psi.After it warms up it stays around 30psi at idle.I had a van with the same engine oil pressure was about the same till rod bearing started going bad.
