Oil pump / Pan removal help please for 96 Blazer 2wd
Got a big issue w/ removing the oil pan in a 1996 2wd blazer.
I am not sure if some other threads apply since they are 4wd or other years. The bolts are all out and working on removing the timing chain cover. Old silicone is hard to budge. Am wondering if there are any clear cut steps or instructions for removing the oil pan to make sure I haven't missed anything. Any help is VERY appreciated! |
Use the 'search' function for "oil pan" in the thread title and check the thread hits you will get.
| All times are GMT -5. The time now is 11:01 AM. |
