-   -   Oil Sending Unit (https://blazerforum.com/forum/engine-transmission-35/oil-sending-unit-78442/)
Ash's Blazer Apr 6, 2013 09:09 PM
Oil Sending Unit
Where is the oil sending unit? In a previous post someone said it was located above the starter on passenger side engine.
- I have a frick'n BAD oil leak coming above the starter, running down engine AND bell housing, flowing back to tranny pan and dropping at 3 different points Sheez! This makes a serious mess of our city streets and downright pisses me off.
PS - What is on the front of the engine just in front of intake about the size of 1/2 can of coke. Boy that sure looks like an oil sending unit to me. Screws into engine and has wire connectors on opposite end???
Captain Hook Apr 6, 2013 09:16 PM
OPSU is located toward the driver side of the distributor, kinda half under it. The 1/2 coke can could be the EGR valve?? Front center of the engine. This is assuming you have a 96 or newer W or X engine.
