Over heats at idle cools off while driving
99 Chevy blazer 4x4 4.3l vortec. Over heats when sitting at idle for a few mins and cools down after driving for a little bit.
not exactly sure but maybe it could be a bad sensor? or maybe the fan kicks in only when you are driving? Just a thought
Check out your fan clutch. If the blades are free-wheeling with the engine off, then that could be your problem. Fan clutches do go bad occasionally. overheat at idle is a common symptom.
Or a partially plugged radiator
