-   -   Oxygen sensor (https://blazerforum.com/forum/engine-transmission-35/oxygen-sensor-72352/)
slash3359 Jul 17, 2012 09:08 PM
Oxygen sensor
A mechanic told me that an oxygen sensor could cause a misfire in the number four cylinder. Is this true or is this false information?
WalkerTech Jul 18, 2012 04:32 PM
Slash,
I am a Product Specialist with Walker Products, a manufacturer and worldwide distributor of oxygen sensors. An oxygen sensor cannot directly cause a misfire on a particular cylinder. What a malfunctioning oxygen sensor can do is contribute to an improper a/f ratio, which can cause drivability issues.
I would start by looking at your spark plugs and fuel injectors as the possible causes of your misfire.
TMM217 Jul 18, 2012 05:01 PM
Yeah i agree. Check your spider injector. I had installed an after market spider on my 4.3 and i had a wire on 1 of the injectors rub on the upper intake causeing a continues pulsing injector that caused the misfire. Good Luck
