Oxygen Sensor, Which One?
Old Jun 7, 2012 | 05:42 AM
Falken's Avatar
Falken is on a distinguished road
Default Oxygen Sensor, Which One?
I have a 2001 Blazer ZR2. I got the check engine light code read and I need to replace the oxygen sensor from Bank 1, Sensor 2. So which one is that? The Advanced Auto parts guy didn't know, and in fact according to their computer I should have 4 O2 sensors and told them I only found 3. I just need to know which one it is, I am thinking the one by the C.Converter, but not sure.
Old Jun 7, 2012 | 07:17 AM
50lb_cat's Avatar
P0137? Should be the post cat converter.
Old Jun 7, 2012 | 07:38 AM
It is the post-cat sensor.
Before you replace an emissions monitoring sensor, clear the code and see if it comes back.
What was the code? Diagnose the problem before spending money.
Old Jun 7, 2012 | 11:29 AM
50lb_cat's Avatar
+1, the cat may be bad. If the cat is bad you should figure out what killed it. Have you noticed a drop in power and mpg?
Old Jun 7, 2012 | 10:53 PM
Falken's Avatar
I haven't noticed any loss of power and I don't know specifically what the code was that they read. I did clear the code out and the light comes back on each time after driving for 10-15 miles.
I will probably just replace the sensor after the converter, clear it and see what happens.
ronaldo
May 10, 2010 08:17 AM
steelcityneal
Jan 10, 2010 09:23 PM
riverjamie
Jan 3, 2008 05:15 PM
andyjwood
Oct 29, 2006 02:51 PM
jmd57win
Oct 27, 2006 10:24 PM
