-   -   Oxygen Sensor / Vacuum Leak (https://blazerforum.com/forum/engine-transmission-35/oxygen-sensor-vacuum-leak-75775/)
Little Roober 12-13-2012 07:03 PM
Hey guys. I've got a code for sensor 1 bank 1. I've replaced the sensor twice and still get the code. I've heard this can also mean I've got a vacuum leak somewhere. Could you tell me which (if not all) vacuum lines would cause this? Or which lines would be a more probable cause for the code? I basically just need some help starting in the right direction.
Thanks,
Steve
xgiovannix12 12-13-2012 07:08 PM
whats the code?
Little Roober 12-13-2012 07:14 PM
P1133
Also, I've had trouble with my HVAC freezing (not blowing any air, hot or cold) once the temp drops below 32*. Not sure if it's related or not.
xgiovannix12 12-13-2012 07:16 PM
yea sounds like an vac related Id start by the distributor and follow all the vac lines till you find the issue.
Edit: also this should help you
P1133 - HO2S Insufficient Switching Bank 1 Sensor 1
Little Roober 12-13-2012 07:31 PM
Thanks man. We'll see how it goes, I guess.
xgiovannix12 12-13-2012 07:35 PM
NP your best bet is start checking your vac lines 1st by the distributor cap and then go on from there.
Little Roober 12-13-2012 07:43 PM
Delete
