P0107 1995 Jimmy - Procedure to replace MAP sensor
Hey guys. I pulled a P0107 code from my 1995. Points to faulty MAP sensor. I bought one. Now is there any tricks to replacing it? Or do I just unplug the battery, swap the sensor, plug the battery in and fire up?
pretty much. you probably dont even need to unhook the battery just leave the truck off. but just to be really safe you can disconnect it
| All times are GMT -5. The time now is 07:29 AM. |
