p0172 p0138 help
going on a limb here, rich on bank 1. the 95 is a older style cpi engine with the problematic fuel system. 2 things happen, fuel pressure regulator leaks or the nylon fuel lines in the intake to the injector "nut kit" leak.
Seeing rich bank 1 from both sensors and the nut kit is on bank one side i'd say it is leaking raw fuel into the engine. Have a fuel pressure and leakdown test done or simply remove the upper intake and look for evidence of fuel washing, clean=fuel leaking(bad) black and sooty=good
XxIRISH63xX
Jun 9, 2011 09:30 AM
jdpilot
Jan 29, 2008 07:20 PM
