1996 Jimmy 4.3 Vortec
Old 02-09-2018, 12:39 PM
Rippy's Avatar
Rippy is on a distinguished road
Default 1996 Jimmy 4.3 Vortec
Almost everything on the vehicle has been replaced/rebuilt. Vehicle ran great, then P0134 (the code number may be wrong but this was the code result bank 1 sensor 1 oxygen sensor) I replaced it, vehicle ran even better. Drove it for 245 total afterwards miles then the tach jumped and dropped to 0 and the vehicle failed to start hasnt started since.
Old 02-09-2018, 04:51 PM
christine_208 will become famous soon enough
Does it crank?
I replaced an O2 sensor on my '92 but what I was doing turned out to be addressing a symptom and not the cause of the failure; a failing fuel injection spider.
Turned out the leakage from the fuel injector was dumping gas directly into the intake causing an over rich condition with lots of carbon build up on the sensor.
Old 02-10-2018, 04:17 AM
Rippy's Avatar
Default 6 times I had to replace this fuel pump
Spider and pump, relay and filter all new. Fuel pump and relay are delco not delphi.
Old 02-10-2018, 11:25 AM
So it does crank but just won't start?
Any other electrical systems not working?
I'd double check that there is pressure in the fuel lines. Can you hear the pump working?
Old 02-11-2018, 08:54 AM
Rippy's Avatar
Default Just replaced fuel pump and spider a month ago. It was running showroom new until
Fuel pump and spider litterally brand new. This is definitely electrical. Like the key was just turned off
Old 02-11-2018, 11:13 AM
Sounds like a key, fundamental part of the electrical system has failed. You might have to go down to the most basic level and work your way up; e.g. start with the battery and battery connections, any fusible links to primary systems etc. That way you can start to isolate where the problem is.
Old 04-25-2018, 03:19 AM
Edz's Avatar
Edz
Edz is offline
Edz is on a distinguished road
Does it crank? No start with starter fluid? Do you have spark?
Old 04-26-2018, 10:24 AM
Rippy's Avatar
Default Fixed
ICM, was a ACDelco part Just went bad after 245 miles. No one makes a product worth a crap these days
mrblonde108
07-17-2017 07:52 PM
bdude273
11-22-2013 08:30 PM
extreme
12-01-2010 06:08 PM
debo42
09-14-2009 06:34 AM
96blkblazer
02-26-2009 04:29 PM
Quick Reply: 1996 Jimmy 4.3 Vortec
