96 Blazer wont stay running
My 96 blazer wont stay running i have done a full tune up the spark is good fuel pressure is right around 55 60 psi i have changed map sensor and maf sensor as well put in a new battery. It will start but bogs down and dies shortly after if i feather the throttle itll stay running but if i let off itll die after a few minutes
Does the SES light come on with key on engine off? If not, figure out why. If it does come on, figure out why your scanner won't connect. Don't use the S.W.A.G. system of diagnosis!! It will cost you lots of $$$$$!!
95blazin
01-15-2012 04:38 PM
millertimee
03-24-2008 01:32 PM
codereddanger84
11-13-2005 02:52 PM
