| little.landen |
Sep 26, 2020 07:10 PM |
P0303- Cylinder 3 Misfire
So I just got done doing the gaskets on my lower intake manifold, and replacing the timing cover. I had some issues putting the distributor back in, and I was sure I was off a tooth because the engine was running really rough. This is when the P0303 code showed up. I ended up taking it in to a nearby shop to see if they could get to the bottom of the code. Supposedly, they put in the distributor correctly, but it still had the misfire. They claimed it was because spark plug number 3 probably was burnt out. They also said my spark plug wires were fine. I ended up replacing this spark plug, but the misfire was still present. I replaced my rotor and distributor cap as well (cap contact points looked to be pretty corroded), but the misfire is still there as well as the code. What else could be causing this misfire, and how can I diagnose these?
