P0455
Old Sep 22, 2016 | 03:54 PM
Jimmy_Blazer's Avatar
Jimmy_Blazer is on a distinguished road
Default P0455
Hi all, 04 Blazer, check engine light came on so I scanned it and it came out with P0455 evap emissions controls. I put on a new gas cap and it went off for about a week then the light came back on with the same code. I checked the evap canister lines and the purge solenoid lines and everything seems fine. What else could it be leaking?
Old Sep 23, 2016 | 12:54 PM
abig84's Avatar
can be anything under there if it just has a reallly small leak. one stupid thing you can check is the filler neck where the gas cap tighens down on. make sure it isnt a rusty mess. if it is just lightly sand it down and maybe put a bit of grease on the seal.
but really the proper way to diagnose these issues is with a smoke machine and you have to smoke the entire system. most common issues i see with gm's are the vent valves cracking or just not closing all the way
Old Oct 1, 2016 | 06:29 PM
I crawled underneith and think I found it. The little canister above the spare tire that has the hose come from the evap canister was a bit loose. Pushed it back on and the light hasnt come on yet. Fingers crossed it stays off lol. Hopefully will fix my bad mpg, was getting 14-15 highway as opposed to the 20-21 I was getting.
HamToast
15
Jan 16, 2014 02:22 PM
brian400ex
Mar 10, 2013 07:15 PM
cbenslay
TrailBlazer GMT360/GMT370 (2002-2009) Tech
Dec 29, 2010 07:10 AM
