p1870 code
p1870 code
I'm replacing the tcc valve since i'm getting the p1870 code and the symptoms that go with the code. I'm using the fitzall tcc valve.
Is it a bad idea to replace it without removing the valve body? I have instructions that say to bend the retaining clip to get the valve past the clip.
If i need to remove the valve body are there any surprises to expect? will any of the ball bearings fall out?
knightryderx2
02-27-2010 12:10 PM
