-   -   P1886: new solenoids, good grounds, good volt @ fuse, help! (https://blazerforum.com/forum/engine-transmission-35/p1886-new-solenoids-good-grounds-good-volt-%40-fuse-help-65838/)
Rselarep 12-10-2011 12:45 PM
1996 blazer 4wd 4.3
I replaced the solenoids, checked all the grounds and wiring @ the harness, had the right voltage @ the tranny fuse (good ignition switch) and the code is still back!
Anyone have any idea whats going on? Where else can I look?
pettyfog 12-10-2011 02:09 PM
Well, here's a guy had the same problem..
Trans OBD II Code P1886 Trouble. - Car Forums and Automotive Chat
My guess, if it's not wiring, and it seems to shift fine manually it's probably in the valve body.
Did you recently have a fluid change?
Blazer Steve 12-10-2011 09:15 PM
Give Transgo a call
Product/Tech Support/Contact:
Give our technicians a call at (626)-443-7451http://www.transgo.com/images/MC900433907%5B1%5D.PNG
8:00am to 4:30pm Monday-Friday "Pacific Time" zone
"CLOSED for LUNCH from 12:00pm-1:00pm" daily.
Rselarep 12-11-2011 03:54 AM
I changed the fluids and filter when I swapped in the new solenoids, would a new valve body be expensive? Could I clean out mine?
When I put in the new solenoids the code came back immediately when I turned the blazer on and put it in drive. It does shift fine through all the gears manually.
P.Martin 12-11-2011 07:14 AM
Hello!
95 was PWM .99 Case Diameter 10-15 Ohm
96 was On/Off .89 Case Diameter 20-31 Ohm
Check resistance on Trans.connector between Pin E and S
( 20-31 Ohm or a bit more for a weak internal harness...)
Check Pin N (Range A) to Gnd = Open ore 250k up
Pin P (Range B) to Gnd = 5 Ohm..
Pin R (Range C) to Gnd = Open
mfg Martin
