p300 code with low fuel pressure
Hey guys ,
At last got enough free time to work on my 96 blazer. Did a fuel pressure test tonight the following is the results..... Key on fuel pressure scored a 62psi then started to fall all the way down to a 20psi I performed a leakdown test for 10 min and needless to say pressure would not hold. I went all the way down to a 10psi ( less than 10 min to stop) could this be the cause of my multiple miss fires? new wires,plugs,DCcap and rotor. Help 96 blazer 4.3 |
| All times are GMT -5. The time now is 11:05 PM. |
