Plenum Torque specs
I've had the plenum off of my 95 Jimmy a couple of times now. Once was to change the CPI and the other was to make changing the distributor cap/rotor easier. I'm curious, if there are any, what are the factory specs for torquing down the plenum? I don't know if mine's over torqued or under torqued or if it even matters. I had one mechanic tell me not to worry about it, but with my chronic OCD, I do worry about it.
EDIT: I've actually had the plenum off 3 times. The third time was to change the gasket that I pretty much destroyed the first 2 times I removed it. |
Tighten the bolts to 10 N·m (88 lb in). I know on my 1997 which has a different manifild, they have 2 passes. 1st pass at 44 in-lbf and second pass at 88 in-lbf. Remember these are in - lbf., so it is not a large amount of torque.
The sequence starts with the 1st bolt to the left of the throttle body and proceeds clockwise ending with the 10th bolt on the right side of the throttle body (Looking from the front of the vehicle). Actually the 10th bolt is in line with the throttle body, it's the 9th that is just to the right of the throttle body. I was not sure how to paste in teh picture. |
1 Attachment(s)
Originally Posted by ejschultz
(Post 244506)
EDIT: I've actually had the plenum off 3 times. The third time was to change the gasket that I pretty much destroyed the first 2 times I removed it. Removal & Installation The CMFI assembly is mounted to the lower intake manifold. The upper intake manifold assembly must be removed for access. The CMFI assembly includes a fuel meter body, gasket seal, fuel pressure regulator, fuel injector and six poppet nozzles with fuel tubes. Should a failure occur in any components of the CMFI unit, the entire assembly must be replaced.
Click to Enlarge
CAUTION To reduce the risk of fire and personal injury, be ABSOLUTELY SURE that the poppet nozzles are firmly seated and locked into their casting sockets. An unlocked poppet nozzle could work loose from its socket resulting in a dangerous fuel leak.
Click to Enlarge
Here are the numbers for a Vin W 4.3l Upper Intake Manifold 124 in/lbs or 14 Nm. [IMG]file:///C:/Users/Owner/AppData/Local/Temp/moz-screenshot-19.jpg[/IMG] |
Thanks for the replys, especially the one with the pics. Now, do you know where I can find a cheap but reliable torque wrench?
(Post 244558)
Best bet is Harbor Freight Tools. http://search.harborfreight.com/cpis...ench&Submit=Go If you have a store near you, they also have an online version for their stores at www.harborfreightusa.com. You can sign up for their emails which routinely provide 20% off coupons on nonsale items. |
Originally Posted by Licklog
(Post 244633)
wow, this is good to know. especially that i have to check my spider in my 95 S10. has anyone ever bought a remanufactured spider injector from rockauto before? is so how was the quality? did it run good after? im considering buying it from them and was wondering any info or experiences from others who have bought it from them. let me know
thanks |
Originally Posted by bigdaddykane93
(Post 244694)
thanks |
Well I torqued the plenum back to where it was supposed to be, and it didn't change anything. It was definitely over-torqued. 124 in-lbs is pretty much right where you start to feel resistance when you're hand tightening the bolts.
I guess it was worth a try; too bad it didn't fix anything though. |
THanks!
Just want to thank posters for pics and info... I replaced Fuel pressure regulator and surging stopped, motor runs great! The previous owner had spent 10 years chasing the problem of shuddering (I changed rear u- joint) / surging and shaking - cause of missfire was gas spewing out of regulator n causing fouled plugs on passenger side
| All times are GMT -5. The time now is 12:27 PM. |
