-   -   Poppet o-ring (https://blazerforum.com/forum/engine-transmission-35/poppet-o-ring-22756/)
fondo 08-23-2008 04:07 PM
Poppet o-ring
Hey everyone, I'm new to this forum so hi. Technically I own a blazer, it just has an oldmobile logo on it. Any how, Its a 1993 olds bravada and I'm going to be replacing the fuel regulator on the cpi spider. I would also like to replace the poppet o-rings if I can find some. Can anyone tell me where I might get these o-rings or even the size of this o-ring. I purchased the fpr along with the supply and return lines from napa and would like to know if they are good quality parts and also if this fpr is the updated version. I'm gonna try take care of this over labor day weekend so I would like to have everything I need before then. I've searched the forum and have found alot of good information, just nothing about o-rings. Great forum by the way... Thanks
swartlkk 08-23-2008 08:18 PM
RE: Poppet o-ring
Poppet O-rings? Do you mean the O-rings where the nylon fuel lines enter into the CPI manifold?
fondo 08-23-2008 09:00 PM
RE: Poppet o-ring
As far as I'm aware, yes.
fondo 08-30-2008 10:19 PM
RE: Poppet o-ring
e
fondo 08-30-2008 10:21 PM
RE: Poppet o-ring
I guess this design doesn't use o-rings for the poppets, instead manifold vacuum. Thanks lindertech
