possible 4l60E to 700r4??
Old 11-09-2008, 12:28 PM
fourplayinmi's Avatar
fourplayinmi is an unknown quantity at this point
Default possible 4l60E to 700r4??
I have a 92 s-10 blazer 4x4 4.3l not sure on the tranny but I have a donor blazer (93) same motor but has the push button 4wd and not sure on what tranny is in it but if it is a 4l60e how would I go about to get it to work in the other (92) blazer
is it possible to do? please help!!!
thanks
Old 11-09-2008, 01:18 PM
WolfPack's Avatar
Default RE: possible 4l60E to 700r4??
https://blazerforum.com/m_183840/tm.htm
Old 11-09-2008, 01:39 PM
doesnt answer my question though
Old 11-09-2008, 01:48 PM
WolfPack's Avatar
So you wanna put the 93 tranny into the 92 blaze.
I think they added the 'e' somewhere around there...4l60 (which is the same as the 700r4?) up till 92 or 92, then it was the 4l60E.
Wheres Hanr3
Old 11-09-2008, 02:40 PM
yes
Old 11-09-2008, 05:13 PM
You would need to get a stand alone controller ($$$). Find yourself a non-"e" transmission to use.
Old 11-09-2008, 07:35 PM
Leeann_Bravada's Avatar
Leeann_Bravada is an unknown quantity at this point
Yes, the '92 is a 4L60 while the '93 is a 4L60E - '93 was the transition year.
Like Swart said, you want a non-'e' tranny.
Old 11-09-2008, 08:31 PM
okay thanks guys I had a buddie tryin to tell me that I can but I didnt think I could just swap it thanks alot!!
so I just need to look for an 700r4 or a 4l60 correct?
Old 11-09-2008, 08:59 PM
4L60 == 700R4. There were modifications towards the end to increase reliability, but they are essentially the same.
You can use the 4L60E, however, the controller for it is $600-$800 depending on which one you decide to go with. I was looking at putting a 4L60E into my Chevelle and decided fairly quickly that I would be using a 700R4 if I wanted an overdrive automatic.
Old 11-10-2008, 05:23 PM
Hanr3's Avatar
Fishing.
You all had it under control.
Quick Reply: possible 4l60E to 700r4??
