possible lifter noise or just noisy motor?
I have noticed that when the rpm's get to around 2500-3000 rpms I hcan hear what sounds like a lifter noise. So i brought it back to the dealer i bought it from because it came with a warranty. The mechanic there said that this noise is due to the fact that the 4.3 vortec is a noisy engine. Also the noise is due to the fact that the 4.3 vortec has a solid lifter cam and lifters instead of being hydrolic. Is this true or do i have a big problem here? Could it also be the oil filter?
RE: possible lifter noise or just noisy motor?
You do not have a solid lifter cam. Unless someone put one in there. You should have a hydrualic roller cam. Someone is blowing sunshine up your skirt.
What does your oil pressure look like? |
it sounds like they just dont feel like looking into the problem........ if you just bought it i would def bring it back...i can hear it now the warranty runs out and your engine goes on vac leaving you to pay the bills...............
I just thought about this, did it make that noise after you plugged up the vaccuum port??? I saw you posted you found the missing link.. |
the oil pressure when the motor is cold is around 60. Once it warms up it is 60 when driving and when stopped it is 40. I was thinking maybe it is th eoil filter that they put in. No the noise was always there. But if it was a lifter problem wouldn't it be there all the time and not just in the higher rpm range?
sounds like theoil pump i am experiencing the same thing im trying to replace it as am typing
| All times are GMT -5. The time now is 10:03 AM. |
