Sponsored by:
Sponsored by:
problems and some more problems
Old 04-07-2011, 04:43 PM
Aanenson's Avatar
Aanenson is on a distinguished road
Default problems and some more problems
ok, my blazer is misfiring/shuddering usually at 45-65 range in overdrive, ive replaced both o2 sensors on both banks, got a new injectors, new plugs, wires, rotor, cap aand its still doing it. The blazer is a 2001 4 door with a 4.3 vortec 4wd autotrac.
Old 04-07-2011, 07:05 PM
atvwarrior's Avatar
atvwarrior will become famous soon enough
Is the engine light on ?
Old 04-08-2011, 08:21 AM
Aanenson's Avatar
yes it is and we ran scantool on it and it was running lean but the pressure in the line is at 60 so the pumps good and my 4wd drive lights on but its just a bad switch.
Old 04-08-2011, 08:59 AM
Frog's Avatar
Frog is on a distinguished road
Shuddering could be to due to Torque Converter Lock-up....try this, when you are driving it at 45-65 and the shudder occurs maintain that speed and tap the brake pedal(do not take foot off of gas maintain the speed)lightly. If the shuddering stops it is a Torque converter Clutch problem. The TCC locks up the shafts to make sure there is no stall speed occuring.
If nothing changes then I would double check all the plug wires to make sure they are fully seated and locked on...at the distributor and the plugs themselves.
Old 04-08-2011, 04:57 PM
Aanenson's Avatar
hmmm never thought of that ill give that a try thanks!
Old 04-11-2011, 09:22 PM
Frog's Avatar
You ever get a chance to test out your torque converter?
Old 04-13-2011, 11:23 AM
Aanenson's Avatar
yes i did and it does stop the shuddering but not every time i hit the brake though but ill ask my instructor and see what he says.
Old 04-13-2011, 05:25 PM
Aanenson's Avatar
im gonna put additive in the tranny oil and see if it works then it be the torque converter as the friction discs are worn out
Old 04-14-2011, 09:12 PM
Aanenson's Avatar
yep put the shudder stop additive in it and it stopped it so now we know its the torque converter!!
joshn444
02-23-2014 12:24 AM
myxil
01-16-2014 06:26 PM
Chenzo
Engine & Internal
03-29-2011 01:56 AM
dougs10
12-14-2010 03:24 PM
victoryredblazer
Nitrous, Super Chargers, & Turbos
07-12-2005 11:58 AM
Quick Reply: problems and some more problems
