Question
Old Mar 8, 2020 | 08:41 PM
The main man austin's Avatar
The main man austin is on a distinguished road
Default Question
So I went mudding and got stuck in my 98 Chevy blazer 4wd 4 door and well I got pulled out and well now it won’t fire I checked the fuses had one blown after changing it the fuel pump powers up and the motor will turn over but won’t fire and I don’t know what is going on some one please help me
Old Mar 8, 2020 | 09:21 PM
Did part of the ignition system get wet?
Old Mar 8, 2020 | 10:53 PM
Default Question
lt was in water I had water up to my drivers speaker in the door but when I hit the water hole I lost all power instantly it shook the battery loose and I blew the number 2 fuse in the fuse box inside the drivers door
Old Mar 8, 2020 | 11:31 PM
Default Question
Well I pulled a spark plug and it didn’t show signs of water in the motor but it was in the water for 2 days and I pulled the oil dip stick and no signs of water but the whole top of the motor had mud water splashed on it
Old Mar 9, 2020 | 02:10 AM
Sounds like you got bad wiring now after sitting in water/mud for 2 days.
Old Mar 9, 2020 | 11:53 AM
Pull the distributor cap and look for water in the distributor. Blow it out with compressed air, if you have it available. Then put it back together and check for spark.
Old Mar 11, 2020 | 04:43 AM
Start from the battery. Check all the battery cable, ground strapping. As you have shaken loose the battery it might as well have damaged one of the cables. With that said, just one blown fuses rises my suspicion. Check for more blown stuff.
Lucky you, kept the engine dry inside, so it seams.
mjink.11
Mar 18, 2013 11:07 PM
CaldwellJonathan
Feb 19, 2013 08:43 AM
95blazin
Jan 15, 2012 04:38 PM
mkemu80
Jan 8, 2010 08:25 PM
jetsmy
Aug 1, 2008 10:10 PM
