Originally Posted by tfcman
(Post 460373)
OK, Reverse 1 and 2 shift fine. When it is time for 3rd, it does not engage and revs like it is in neutral.
you could adjust the pressure but as swartlk said it probably would cure nothing it would just mask the problem or cause others so...kinda sounds like forward clutch pack may be slipping or fried
Go guys with my problem of not having a first gear shift is clutch packs are about fried or is there any other things I can look into to make this last a while longer.My transmission man said that the piston on the side I can drill a hole and put stiffer spring in it to help.Anyone ever did this?
| All times are GMT -5. The time now is 12:30 PM. |
