quick question about transfer case removal
(1996 4x4 Automatic)
I'm knee deep in my engine replacement project, working on it an hour here and an hour there. I'm at the point of removing the transfer case.
My question is this. I've read you have to remove the transmission cross member, support the transmission, all that good stuff. But I'm not sure where to separate the transfer case from the transmission.
There appears to be two places where I could separate them.
It looks like I could leave the transmission cross member in place and unbolt the transfer case from the bracket that holds everything to the cross member. If it will separate here, I wouldn't have to remove the transmission cross member right away.
The other option appears to be to remove the cross member and then unbolt the transfer case from the transmission taking the mounting bracket out with the transfer case. This option requires that I keep the transmission supported because the cross member would be out.
Does that make sense?
Where do I separate the two?
Thanks!
Thanks!
Ive always left the cross member when pulling the t-case... much easier that way. Just remember there is a seal between the t-case and trans adapter that will have to be replaced / RTV'd when you reassemble.
If I can separate the t-case after the cross member bracket and leave the transmission supported on the cross member that would be very cool.
from my experiences always take off the bolts attaching the transfercase from the adapter. anytime ive ever taken the bolts out of the transmission itself they always seem to rip up the threaded holes for some reason. some s10s kinda suck due the torsion bar crossmember being back there and it maybe tight getting that transfercase out of there but it will come out
Flyfishen
Jun 18, 2019 11:22 AM
VRDriver4l
26
Jun 5, 2011 07:42 AM
dj00140
May 24, 2010 04:49 PM
