-   -   radiator grille (https://blazerforum.com/forum/engine-transmission-35/radiator-grille-9156/)
rickjbr 03-06-2007 11:23 AM
radiator grille
Hello, I'm trying to replace the headlights and am having a hell of a time removing the radiator grille from my 96 blazer suv. Any tips appreciated, and yes I've removed all the screws, unless there are some that I missed. I believe there were 6 in all but I can't quite remember. Are there more? Thank you.
MNHawk 03-06-2007 04:46 PM
RE: radiator grille
there are clips that hold it in also. Do a search there was a post with an image of where the retaining clips where.
20Blazer00 03-06-2007 05:58 PM
RE: radiator grille
All you have to do is to start at the top of the radiator core support by the hood latch and pry back with fingers or flat pry-bar or screwdriver and pull out the grille....there should be no screws to hold it in place??? at least to what documentation I have....(GM Service Information DVD it does not go back that far with exterior trim panels)...
