Random/multiple misfire
My 2000 Chevy Blazer keeps throwing the P0300 muliple/random misfire code. Im stuck on where to go now. I have replaced plugs, wires, cap, rotor, fuel filter, air filter, spider injector and I removed my cat and installed a pipe. Any help would be greatly appreciated. Thanks
- I saw last night while checking something else I have P0300 pending. I know why.. needs tuneup.
When does light come on, in particular? at steady speed/ cruise? While idling?
If you used Bosch Plats.. start there. If you used Autozone budget wires/cap/rotor.. replace those as well.
Do you have starting problems when raining or damp overnight?
Run engine in dark, look for arc-over.
- cant hurt to clean the coil tower and lube it and wire with silicone lube or spray.
Check cap inside and rotor for signs of wear and friction rubbing deposits, etc.
While there wiggle rotor.. any signs of slop?
See next post..
Know anyone with a timing light?
Hook to #1 and look at the crank pulley with engine idling relatively smooth, any identifying marks on pulley will do.. do they jitter or dance? Distributor slop!
b_didddy510
Mar 29, 2019 06:57 AM
99midnightLT
23
Sep 2, 2011 02:12 PM
Coolkat
Jul 3, 2011 12:46 PM
