| rrk03300 |
11-14-2012 11:03 AM |
Randon misfire: adding auxilliary vacuum pump to fix misfire at idle on 2000 Blazer
I have a 2000 Blazer with a weak cylinder (#6) that idles roughly and occasionally misfires on that particular cylinder. cylinder 6 has 120# and the others have 170# of compression at the moment. The thing runs smooth and strong at all other times...not surging, misfires, etc. while driving once the throttle is tipped. But when i let it sit and idle for more than about 30 seconds the engine starts to misfire on cylinder 6...popping out of the tail pipe and throwing up a code for misfire on cylinder 6. I believe i may have an intake leak but have no apparent signs of coolant seepage at this point. All of my vacuum operated systems seem to be working fine...occasionally the heat switches from the floor to the dash when driving up hills for long distances...but otherwise no other inconveniences. I have inspected for vacuum leaks and ran a vac test which shows it does drop below 16 psi at idle...to about 12psi. or so (I didn't let it run long as I fear fouling the plug eventually). I have been checking other posts regarding misfires and from what i believe i may be experiencing a lean misfire condition at idle due to the drop in vacuum and how that drop in vacuum effects sensors...leading to the fuel being trimmed back and causing a lean condition at idle. As cylinder #6 is weak it misfires right away. Does this make sense to anyone?
Anyways...the reason i'm posting is i would like advice on installing an aftermarket vacuum booster to help increase my engine's vacuum at idle to see if that helps. I know that hot rodders like to use these to increase vacuum on high compression engines to help ensure enough vacuum at idle for braking. The ones i have seen online are installed inline between the intake and the brake booster and include a selenoid that kicks the pump on only when vacuum drops.
Again...does this make sense to anyone out there? I really am just trying to avoid replacing intake gaskets on this thing as the last time i had it done the shrapnel from the removal and cleaning of the gasket surfaces ended up down in my front main bearing, taking my crank and mains out and ruining my engine, necessitating replacement with the one that's in it now. I know these 4.3's are notorious for leaky intakes...have owned 2 S-10's over the span of 16 years with each getting 2 engines apiece due to intake leaks and the subsequent bearing failure following intake gasket replacement.
